Neue S&S / Flatheadpower Knuckle(Style) Motoren
hab grad einen S&S Newsletter bekommen in dem die Vorbestellmöglichkeit für die neuen KN-Motoren angekündigt wird. Irgendwie ist´s bislang an mir vorbeigegangen das die S&S Jungs zusammen mit Flathead Power nun auch "neue Knuckleheads" auf den Markt bingen. - Mag man zum Thema "Original gegen Aftermarket" stehen wie man will, ich find´s ne gute Sache und dachte ich laß Euch das mal als Info zukommen.
__________________________________________
S&S Cycle
Press Release
FIRST EVER KN-SERIES ENGINE PRE-ORDER OPPORTUNITY
LA CROSSE, WI (October 10, 2008) S&S® Cycle announces the first ever opportunity to pre-order the all new Flathead Power™ by S&S Cycle KN-Series engines. During calendar year 2008 there will be only 100 of these beautiful vintage engines produced—available in generator (PN 106-2161 MSRP $8575.00) and alternator/generator (PN 106-2560 MSRP $8750.00) styles—with serial numbers that identify them as the first 100 produced. Considered one of the most desirable engines ever, this is a great opportunity to lock one in for your next build.
Currently 40 KN-Series engines are already on order just from the sneak preview in Sturgis this year, leaving 60 more to be built. Expected shipping on these engines will start during the first week of December, so if you want to guarantee one for your next project, contact an S&S Customer Support Representative now. A non-refundable deposit of just $500 will lock in your place in history.
The Flathead Power by S&S KN-Series engine features the aesthetic looks of classic iron, but benefit from significant upgrades. For starters, displacement is 93 cubic inches, because you can’t go wrong with more power. One big improvement is the use of a 1958-’65 style flywheel assembly with a splined sprocket shaft and Timken sprocket shaft bearing. This change necessitates the use of a 1954-’65 tin primary cover and primary chain sprocket—but the increased flywheel stability, strength and power capacity are worth the stock departure.
Flathead Power rocker arm cover “tins” are another modern improvement. The lower covers are actually made of die-cast aluminum, and instead of being held in place by the valve guide, they are held down by valve spring pressure. A special gasket on the bottom of the lower “tin” provides a positive seal, and is much easier to service if needed, since the valve guides do not have to be pressed out in order to remove the lower covers. Also instead of the steel brazed-in hard oil return lines used on stock tins, S&S has improved the design of the oil line for better reliability and easier assembly and maintenance.
“We are very excited to finally be able to launch the Flathead Power 93ci KN-series engines. There has been over 14 months of refinement that went into getting them ready for this announcement,” said Charlie Hadayia, S&S Senior Sales Manager.
Bild[/img]
panshovel
Re: Neue S&S / Flatheadpower Knuckle(Style) Motoren
Beitrag von panshovel »
Accurate Engineerig baut die Afterknuckles eh schon länger nach. Fragt sich wer die bessere Qualität hervorbringt. Denke aber dass Beide ziemlich die gleichen Parts verbauen werden. Auf jeden Fall wäre so ein Aggregat mit Sicherheit eine interessante Sache. Wenn es nur die Gesetzeslage zulassen würde so ein Teil zu verbauen - (zumindest bei uns würde mir kein Weg einfallen).. :?:
panshovel
Guckst du da
http://www.accurate-engineering.com/cus ... nuckle.htm
Über 100 Cu " - mächtig :evil:
bobber
Beitrag von bobber »
und was soll der Spass kosten?
Die nachgebauten Panheads weit über 6000 und das ist ne Menge :roll:
vampyr
Beitrag von vampyr »
panshovel hat geschrieben: Wenn es nur die Gesetzeslage zulassen würde so ein Teil zu verbauen - (zumindest bei uns würde mir kein Weg einfallen).. :?:
Nur mal ne Frage, warum kann man von Gesetzt wegen so einen Motor nicht verbauen?
Gruß Thorsten
panshovel
Guten Morgen.
Wie du siehst, schreibe ich aus Wien. Hier könntest du als Neuaufbau weder einen Pan oder Shovel oder Knuckle zum Verkehr zulassen. Wenn so ein Motor bereits zum Verkehr zugelassen wurde - dann vielleicht als Tauschmotor. Doch auch da bin ich mir nich so sicher. Neuaufbau ist auf jeden Fall unmöglich. Auch kannst du hier keinen Starrrahmen als Neuaufbau zum Vekehr zulassen. Vielleicht ist es möglich auf dunklen Wegen diese Verordnungen zu umgehen, aber auf geradem Wege - keine Chance. Ich wollte bei meiner Shovel anstatt dem 19 " Vorderrad ein 21 " Rad eintragen lassen - also eine Lapalie... KEINE CHANCE.
Dafür ist eben in meinen Typenscheinen so gut wie nix schriftlich eingetragen. Lediglich 2 schwarzweiss Fotos, die Fahrgestell und Motornummer die Dimension der Reifen, die Abmessungen (Radstand) und die Lautstärke und die Funktionsarten der Bremsen (mechanisch-hydraulisch) Sonst nix.
Gruss - Jürgen -
