Neues für Altes von BAKER
Mahlzeit,
ich hau mal ein bißchen die Werbetrommel in eigener Sache....ihr werdet es überleben... :-)
Von meinem lieblings Getriebehersteller gibt's demnächst ein paar Neuigkeiten für unsere alten Eimer.
Zu beziehen...geeeenau...bei mir! :-)
Hier als (fast) exlusiv Vorschau:
BAKER Alu-Primär im Blechprimärlook:
Available in starter or kick only applications. BAKER took the classic 1936-64 tin primary design and re-constructed it with aircraft grade 6061-T6 aluminum to facilitate 1970-E84 Big Twin alternator motor case compatibility. BAKER addressed leaks, reduction in chain noise, and make modern starter integration possible. The Modern internal design of the primary utilizes stock style double row primary chains (428 chains) along fine tooth and L-bracket chain tensioner. The chain oiler feed and return provisions mimic the original primary setup so you can run your stock Shovelhead dry clutch components or leave it plugged off to run a wet clutch setup.
Starter version is setup for factory 1.4kw 1990-2006 starters. Compatible with traditional tin derby and inspection covers or BAKER TTP Covers (sold separately). The TTP utilizes the 1955-64 non-compensator style motor sprockets in order to keep that tight/sleek appearance. Primary drive configurations are -24 tooth motor sprocket, 37 tooth clutch sprocket, and stock 82 pitch primary chain, for a 1.54 primary reduction. 24 tooth motor sprocket is maximum size that fits within the TTP envelope. -22 tooth motor sprocket, 35 tooth clutch sprocket, and 80 pitch primary chain (available through BAKER) for a 1.59 primary reduction. -23 tooth motor sprocket, 38 tooth clutch sprocket, and stock 82 pitch primary chain for a 1.65 reduction. Available bead blasted raw or fully show polished.
BAKER Jockey Top
is a new product to complete the puzzle BAKER started last year with the release of their 4 Speed for 1936-E84 models. The BAKER Jockey Top like the Ratchet Top comes with a snot-slick linear ball bearing detent for that smooth positive „snick-pop‟ shift quality you would expect. Made out of aircraft grade 6061-T6 billet aluminum with hidden vent and sealed shift shaft make this cover leak free. Available in FL / FX shift patterns, blasted raw, wrinkle black or show polished finish.
Neue Kupplung zur Verwendung mit verzahnter Hauptwelle für Shovels. Die Hauptwelle gibt's schon länger als Umrüstteil im Baker Programm
1970-E84 is based off of their 9-plate clutch used on 1990-up applications and fits in the stock primary housing and TTP. BAKER offers 8620 gear steel 35, 36, 37, and 38 tooth clutch sprockets with their clutches, to dial in your overall gear ratio. The new splined clutch comes with or without 66T starter ring gear. BAKER‟s one piece 66T starter ring gear and kick only clutch basket design is made out of 1145 steel, induction hardened T0 45-55 Rockwell C scale for years of wear free use. 9 two-sided kevlar clutch plates, deliver ample holding power for up to 125 ft-lbs of continuous use. Featuring a 6061-T651 aircraft grade billet aluminum pressure plate that is hard anodized for durability and specially designed diaphragm spring with ergonomic break-over feel during engagement yet having strong holding power when you put the throttle down.
Now if you are thinking my Shovelhead has a tapered shaft, BAKER offers the splined Shovel clutch kit. You know the sad story. The torque on the clutch nut backs off a hair and the key on the transmission mainshaft shears off. This usually happens at the most inconvenient time and place. And the probability of this sad story playing out is greater with performance applications. The kit Retrofits and upgrades the stock tapered mainshaft and clutch to a modern 18 tooth spline configuration. Kit includes a fully assembled clutch and splined 4-speed mainshaft to retrofit stock 1970-E84 Big Twins has an 18 tooth mainshaft to install into your stock 4 Speed.
Und...ich weiß zwar nicht was es mit Antriebsteilen zu tun hat, aber sei's drum...die Baker Stash Tube. Werkzeugbehälter / Staufach im Generator-Look
made out of aircraft grade 6061-T6 billet aluminum with a screw on top and a .200” thick O-Ring make for a water-tight seal. Internal diameter is 2.5” by 4” deep giving you plenty of room to conceal your items. Stash tubes come in raw or cat black finish with highlighted fins and fit all Knuckle, Pan and Shovelhead generator right side / alternator left side style motors
Preise und Infos sobald die Teile verfügbar sind auf meiner Shop-Seite.
Zuletzt geändert von Gerry am 01.02.2011, 16:11, insgesamt 1-mal geändert.
Re: Neues für Altes von BAKER
Coole Scheiße! 8)
Der Aluprimär im Blechprimär-Look ist ja mal echt abgefahren. Auf was für Öfen passt der denn, nur Shovels oder auch Evos? Mit Belt oder Kette zu fahren?
Ich hab mal die originalen Ankündigungstexte druntre kopiert. Iss mir grad auf die Schnelle zu viel zum Übersetzen. :-)
DANKE! :wink:
Hi Gerry,
is ja krass, daß die an Stelle die Kupplungsnabe auf den 4Gang-Konus anzupassen, eine verzahnte Getriebehauptwelle mitliefern, was wiederum verständlich ist, da ja auch der Kupplungskorb und Starter im EVO-Style (ab '90) beibehalten werden -> braucht man an der Kupplung und am gesamten Primär garnix machen und hängt einfach den EVO-Kram rein. :shock:
Hi Fauli,
das Design begründen sie mit höherer Haltbarkeit. Ist eben auch typisch für Baker...gerne mal ausgefallen. Der Aufwand ist natürlich "ein wenig" mehr als nur mal eben einen anderen Kupplungskorb bzw. ein anderes Kupplungspaket zu montieren. Bin mal auf weitere Details und Bilder der ganzen Teile gespannt. Die sollen heute noch mit Preisen (die auch *räusper* interessant sein dürften) bei mir eintrudeln, schrieb Herr Baker gerade.
Shovel1978
Beitrag von Shovel1978 »
Gerry, übersetzt Du den Text noch?
Da ich wohl der einzigste im Forum bin
der im Englischen nicht sooooo gut ist und es auch nie sein wird. :oops:
jo...ich schreib da was für die Shopseite zusammen. - Stay tuned. :-)
Shovel1978
Is nett, Danke :wink:
Nabend,
seit der Ankündigung ist schon wieder ne ganze Weile vergangen. Nun hab ich endlich die Infos zum TTP [Tin Type Primary] und die dazugehörigen Preise von Baker bekommen. - Die Infos sind nun inkl. nem kleinen Produktvideo auf meiner Shopseite zu finden:
http://www.bakergetriebe.de/
Die Preise für die anderen angekündigten Produkte stehen herstellerseitig noch nicht fest. Sobald ich alle Infos dazu habe, stelle ich die auch online.
