Tolleranzen Pinniongear
hbf
Beitrag von hbf »
Hallo Forum ,
a)
kann jemand sagen wieviel Höhenschlag das Pinniongear (wenn überhaupt ) haben darf ?
b) Die Lagerpassung / Laufspiel vom Pinnion und Nockenwelle in den Deckelbüchsen bräuchte ich auch !
Danke !
hbf
KayTee
Re: Tolleranzen Pinniongear
Beitrag von KayTee »
Moin hbf!
Laut Service Manual für '70-'78
- flywheel assembly - runout (mainshafts) - .001 in = 0,0254 mm max.
- pinion shaft bearings - cover bushing fit - .0005 - .0012in loose = 0,0127 mm - 0,03048 mm
- cam gear shaft in bushing: 0.0008 - .0018 in. = 0,02032mm - 0,04572mm
- cam gear shaft in bearing: .0005 - .003 in = 0,0127 mm - 0,0762 mm
- cam gear end play: .001 - .0015in = 0,0254mm - 0,0381mm
Viel Erfolg!
KayTee
hbf
Beitrag von hbf »
hallo kay tee
sorry, wußte doch da war noch was , brauch die daten für bj 7/81 !
gruß!
hbf
KayTee
Moin!
Na denn, aus dem 1978 1/2 - 1984er Handbuch:
(service limits)
- flywheel - runout - shaft at flywheel - 0.002 in max = 0,0508mm
- flywheel end play ('80 + '81) - 0,001 - 0,006 in = 0,0254 - 0,1524 mm
- pinion shaft bearing in cover bushing - 0,0005 - 0,0025 in (loose) = 0,0127 - 0,0635mm
- cam gear shaft in bushing - 0,0008 - 0,003 in = 0,02032 - 0,0762 mm
- cam gear shaft in bearing - 0,0005 - 0,003 in = 0,0127 - 0,0762 mm
- cam gear end play - 0,001 - 0,016 in = 0,0254 - 0,4064 mm
So besser? 8)
KayTee
Beitrag von Grisu »
Dann Versuch ich´s mal
Laut Service Manuel 78 1/2 to 84
Gearcase
Breather gear and play...................................... .001-0016in
Cam gear shaft in bushing................................ .0008-.003in
Cam gear shaft in bearing................................. . 0005-.003in
Cam gear and play............................................ . 001-.016in
Oil pump drive shaft ( crancase bushing) .......... .0008-.0025in
Flywheels
Runout (flywheels at rim).............................. .006in maximum
Runout (sha´ft at flywheel)............................ .002in maximum
End play (80´-81) ............................................... .001-.006in
(82 an later)........................................... .001-.004in
Pinion Shaft Bearing
Roller bearing fit (loose).................................... .002-.0008 in.
Cover bushing fit (loose)................................ .00005-.0025 in.
Grisu :twisted:
www.v-bikeparts.de
Beitrag von Grisu »
Und doch zu langsam :(
Grisu :twisted:
www.v-bikeparts.de
hbf
Beitrag von hbf »
moin moin ,
@kay tee & grisu
DANKE !
gruß!
hbf
